Hi!
Today I download the rangefinder files for Sketchup 2018. After printing them, the perplex block doesn't fit on the rangefinder casing.
That measure is correct. I obviously can't slide tha block from the left to the right because it's smaller at the beginning, but if I try to press force it from the top, the perpex block is bigger in that part (34mm). Had to do a lot of force to fit it, is this notmal? Because that way there would be no method to install the light bulbs on the perplex and then slide it in.
