Making the first Rafal Works Helmet
Today I glued on the outer face template, then glued on the half back red paint scheme. Also cut out the cheek area.
This is it for today.
Respect!
Great Job RF! great idea for the multiple struts to keep the dome's shape true. I wish I'd have though of that myself instead of fighting with the standard quadrants.
Thanks, yorkshiredad! We all learn from our or others mistake. It's never too late to start one more scratch build helmet.
Today I glued on some of the paint and scratches scheme for the dome. Although in the images you can see the white contour, on the real helmet is less visible. Maybe if I will cover the finished helmet with lacquer or something will reduce the white lines and the layered paper.
This is the latest stage of the helmet:
Dsc05517.jpg Dsc05515.jpg Dsc05513.jpg Dsc05520.jpg Dsc05522.jpg Dsc05518.jpg
Respect!
Thanks a lot, boys! This thing is getting better and better as I advance with each step. Two things to comment so far: the dome top scratch is bigger than it should be, and the front arrows are farther from the red rim... But so far I'm happy with the result. Today I will glue on the front red paint scheme and add the physical damage to the helmet.
Respect!
As I promised, I'm back with some new build steps. I glued the killstripes to the dome and added the front red paint scheme.
Dsc05526.jpg Dsc05527.jpg Dsc05528.jpg Dsc05530.jpg Dsc05531.jpg Dsc05532.jpg Dsc05534.jpg
Next on the menu: the cheeks.
Respect!
Congratulations. You have not won one million dollars, but you're making the best cardboard scratchbuild bucket I've ever seen. Using this one as a base, and with a few drops of bondo and tweaks you could get a really accurate bucket bud. I applaud your effort.
Thank you for the kind words, KaanE! Just wait to see with the cheeks done. It's amazing! I let the images talk...
Sadly, the printer shop where I printed the templates was closed and I printed the cheek templates at another shop where they had other printer settings and the colors are slightly different in comparison with the dome. And you can see a distorted blue color near the borden connector. But it's OK. This still rocks!
Respect!
