Blaster Fettastic ESB EE-3 Found Parts Build
So rad this is going to be a clone from the clone who used it lol. Do you know how much it will weigh when it's complete?
Haha good one! I mean the Webley's themselves are solid steel and feel heavier than they actually are so I estimate it will probably weigh around 10lb. I will weigh it when it is complete though for sure.
I think mine checks in at around 12lbs. Curious to see where yours sits Cam!
EDIT: Threw her on the kitchen scale and she weighs 8lbs 13oz
12’s a different toy
Thanks to Dana, I got my beautiful barrel mounts and breech discs. Just need to get my scope back, work on my sling, and find 4 accurate Hirschmann AM Plugs.
Alright!!! Finally, I have everything that has been identified and is now in order for this epic, found parts, Boba Fett, ESB, EE-3 Blaster build and will now start the assembly and painting process.
Disclaimer: (Nothing will be permanent or damaging to the original and historic Flare Gun)
Actual Found Parts List:
Webley & Scott No.1 Mk1 Flare Pistol
- Serial # 15849
- Original Bluing Finish
- Original dated stock
- Served and stamped in WWI 1917, WWII 1942, 1943
-Original sling rings
Resources... miscellaneous-webley-and-scott-flare-gun-information
Micro Precision Products (MPP) Micro Flash
- Correct Variant Large B-Port
- Royal Airforce (RAF) military stamp
- Serial # 14A/4678
Webley & Scott 4x20 Scope
- Assumed to be all original
- Correct plastic eyepiece
- Correct locking ring
- Correct tube
- Correct windage and elevation screws
- Correct objective bell
- Correct screw in ring
- Correct tall feet "Hero" scope mounts
Resources... ee3-vintage-scopes-and-scope-ring-types
LMK AM Aerial Earth Plugs
- Quantity (4)
1970's Revell Visible V8 Piston Rods
- Quantity (2)
Unimax Fail Safe Switch type "O"
- Quantity (2)
Mate-N-Lok 6 way Pin Housing
- Quanity (4)
- Disclaimer - Exact Variant Still unknown and unidentified
Resources... PartsofSW
Modeled/Extra Parts List
Breech Disc Greeblie
- 3d Printed
- Modeled from reference photo's
-Actual Disc Greeblie used Still unknown and unidentified
Barrel Clamps
- 3d Printed
- Modeled from reference photo's and after vintage pipe clamps
-Actual Pipe Clamps used Still unknown and unidentified
Scope Mount to Pipe Clamp Mounts
- 3d Printed
-Actual mounts used Still unknown and unidentified
Miscellaneous Nuts and Screws
- All metric sizes
NEW FOUND PARTS DUE TO THE MANDALORIAN
Leather Sling
- Recently discovered leather part made from the hide of a Mature female Blurrg before mating.
- Just Kidding... Amazon.com leather, 18mm wide by 3mm thick, medium brown.
I'll try and remember the process.
Cameron,
can you walk me through the dye proces? It would be helpful if you could pitch at the level of a witless infant.
Andy
This will probably do a better job than me explaining it. It's a long video but everything is in there you should neet. Cheers.
This thread is more than 5 years old.
