Fett Helmet History
Considering the crater they put into Boba's helmet is the same one as on C-3PO, how would they have gone about it? Re-heated the plastic locally with heat gun and pressed in a positive "dent" form? The dented version of the white Supertrooper helmet I've seen looks to still be polished ABS. I doubt they'd've gone to the trouble of cutting out a hole, gluing in a "dent" piece, and then repainting it white before painting it grey...
Also, whoever sculpted it, they used the upper part of a baseball batter's helmet, turned backward, for the dome. I have one that is an exact match in circumference and contours. Too exact to be coincidence. Does anyone on here know who did that initial sculpt, and whether they did both helmet and armor, or just helmet, or what? I don't know how much it matters. I'd just like to know...
--Jonah
The dent was added by cutting a hole and adding the dent...as you can see in the PP2 helmet its very shoddy work....
The Helmet is Fiberglass also not ABS. Dont recall if we know who sculpted it though?
According to the Star Wars - The Blueprints book, the Boba Fett suit was developed by Norman Reynold (using the McQuarrie and Johnston sketches), who was helped by Jan Stevens (or Janet Stevens) as sculptor and Brian Archer as model maker. And F4R is right about the dent being added in the hole that was created in the helmet's dome.
Peregrinus, can you share with us the measurements of that particular baseball helmet?
Tk409 took some wonderfully exacting measurements off a Mystery helmet that, when compared against laser caliper measurements of the ESB and ROTJ helmets on display have shown them to be close enough to the same size as makes no difference. He got a measurement around the base of the dome, above the brow band and without the rangefinder ear in the way, of 724mm. The baseball helmet I picked up is exactly the same.
I was even more impressed when, after removing the hideous earcaps it comes with, I took ~11mm off the back edge of the front half of the dome on my Hasbro Boba helmet and it now has the same shape as the batting helmet, and is 724mm around the base of the dome. :D
--Jonah
--Jonah
Thanks! That 724mm without the right ear is correct (the RWH v2 templates were partially based on the mystery helmet measurements, but other sources too).
C'mon, Art. You've been mum on this for some time. We've since gotten the MR "ESB Hero" that's really the PP3. We've got the eFX Boba. We've got the second-generation plug FP got of the PP2, and the work that's been done with it on here. I do think those need to be added to the family tree. ;)
--Jonah
This thread is more than 8 months old.
