The5thHorseman
Hunter
You're doing a great job here Germain, if I ever make another Webley I'll be following this thread. I love your functional mods to the kit!
Thank you for the kind words Austin.
Now the following of the build.
14) The Molex Connectors. As you can see, they aren't perfectly symetrical in shape.
1. One of the lateral face has an offset...
2. ... while the other is smooth.
3. One of the upper face is smooth...
4. ... while the other has a molded line on it.
Given the fact the Molex connectors aren't symmetrical, it means they have a correct way around. Hence i had to determine the one used for each of the four Molex connectors on the original blaster.
1. The Front/Left Molex is clearly oriented so the molded line is facing upwards.
2. The Front/Right is oriented so the smooth lateral face is facing outwards.
3. On this picture we can see (barely) that the Rear/Right Molex is oriented so the molded line is facing upwards. To confirm that we can also see that the smooth lateral face is facing outwards.
4. The Rear/Left Molex was the hardest to determine. However on this picture the lighting source is directed straight on the Molex yet we cannot see any molded line at its top although on the pic 1. (which is cropped from the same picture) the molded line is clearly underlined by this same lightning. Therefore i concluded this Molex should have its molded line facing downwards.
Once the way of each molex determined, i just had to install them.
1. Each Molex has two pins to secure it to the barrel mount for safety. Even if we can see on some reference pictures that the original blaster lost one of them at some point so i guess its accurate
2. The two front Molex secured to their barrel mount.
3. The two rear Molex secured to the rear barrel mount.
4. Mounted on the barrel, and plug.
15) The Barrel Mounts. To secure the Barrel mounts and their "scope foot" i decided to use screws for both of them rather than glue, still in the idea to be able to disassemble the blaster if needed.
1a. 1b. One of the two "scope feet" before.
2a. I drilled two holes for pins on the bottom face to prevent the "scope foot" from pivoting on itself around the axis of the central screw.
2b. The screw i'm using is countersunk, so i countersunk the "scope foot" top face so it can fit inside.
3. The matching holes for the pins and screw in the barrel mount.
4. The two pins preventing the "scope foot" to pivot on itself.
1. Then i aligned the rear barrel mount on the barrel, making sure its top was at the horizontal. Then i reported the postion of the barrel mount's central hole on the barrel. This way i'm sure everything's aligned.
2. The hole once drilled.
3. 4. The rear barrel mount with its "scope foot" secured on the barrel. I used a Viking nut on the inside of the barrel which was quite difficult to put in place by the way.
1. 2. I reapeated the same process with the front barrel mount that goes on the barrel plug.
3. The two barrel mounts secured.
4. With the molex and the chrome tube. The barrel plug for the front barrel mount and chrome tube isn't glued, the friction being by far enough to lock it on.
That's it for now.
The next update will mostly be about the scope and it will wrap up for the build in itself!
- T5H
