Brak's Buddy's Fett Helmet Project
I know this has been said before BUT VERY nice work man!! :)
Can't wait to see the finished helmet! :)
~Bobby
I really need to figure out how to put that little emoticon with the dropping jaw on here ...that is just so cool. You and Lunn are doing just a great job. I can only hope that I am able to emulate half the jobs that you have done.
Shawn
Brak's: Since you're doing a ROTJ paint job, what colors are you going to be using specifically?
First, the earpieces were just quickly hot glued in place to take the pics. They have not been appropriately attached yet but when they are the rangefinder will work. The visor also is simply being held in place, by tape, for the picture. I am still undecided on how to mount it but I think I may be able to use a slightly modified screw mounting configuration and make it stay in place.
As to the exact paints... I don't know yet, and I HIGHLY doubt I will paint it myself so I will probably leave the colors up to the artist who paints it. Colors are a weakness of mine. Also, I may, UNOFRTUNATELY, have to paint this helmet ESB, because it was specifically constructed to BE an ESB helmet and there are so many things on the helmet that scream ESB that I may not be able to overcome them... That makes me sad but the sculpter set out to make an ESB helemt, not an RotJ and he did an EXCELLENT job.
COME ON BRAK'S, SAD???? It’s an ESB helmet, so just go with it bud! I was actually very surprised being the accuracy freak you are that you even considered otherwise! But, on the flip side of that... Lynns bucket looks pretty damn incredible though, so I really think you probably could go either way. Knowing how you are, you better go ESB! :)
Heh heh. Well, I have been looking a LOT at the differences and there are two things that strike me. Where the ESB visor area (brow trim and mandibles) is very nasty and wavy, the RotJ trim is very clean and neat. Also, the horizontal slot for the RotJ helmet is even MORE narrow than the ESB. So basically the entire visor area would have to be reworked. Second, the RotJ helmet is definitely not as flared at the bottom as the ESB. Some think this is simply due to warpge on the non-rangefinder cheek and I am leaning in that direction too. I am wondering if a well placed chin strap might not pull the helmet together a bit... The only problem is, as Drew has pointed out over and over, when you squish the helmet in on the sides the front and back bow out. I am actually beginning to harass my sculpter friend about resculpting his helmet for this RotJ fan!
Give him some time Brak's I'm sure an ROTJ is in future plans anyhow!! ;) And all of what you had just described in your last post is pretty interesting to me actually... I always thought that the helmets differed solely on size, flare, weathering, and paint. You know your helmets, I'll certainly give you that!! But its within that realm of thinking where I think you'll have to go ESB on this one because it will slowly drive you insane otherwise. :wacko
I was looking at the 2 helmets on the ref CD page and was wondering if anyone else noticed that the rangefinders are different.
the part I'm talking about is the little black square under the rangefinder.
It's on the ESB helmet but not on the ROTJ.
here's a couple of links in case you aren't sure what i'm talking about. they're the best pics I could find of the underside of the rangefinder.
http://www.essat.cl/cdref/0101_0200/Boba_Fett_129.jpg
http://www.essat.cl/cdref/0301_0400/Boba_Fett_310.jpg
http://www.essat.cl/cdref/1001_1100/Boba_Fett_1075.jpg
http://www.essat.cl/cdref/0601_0700/Boba_Fett_602.jpg
the first 2 are ROTJ and the last 2 are ESB.
sorry if this has already been discovered, but since I didn't see anyone else saying anything about it, I figured what the heck.
Good eye! We already knew about that particular detail but it doesn't devalue the fact that you saw it on your own. Keep searching and no telling what you might find. Heck, hopefully something we missed that will actually make everyone's helmet better!
Brak et all,
Maybe I am somewhat confused. Are people more interested in making an exact movie "costume" or a Boba Fett uniform. Why I do not in any way challenge your taste for an accurate "prop" my question is why?
The helmet inaccuracies described are there because it was a movie prop, not IMO what Fett armor should be. A true helmet would not have the wavy visor, warped bottom, misshapen rear grille etc. The lines would be sharp, symmetrical and crisp (unless battle damaged). Same with some other details that mimic a prop, rather than "reality".
For example, stormtrooper "props" had exposed fiberglass edges, painted boots, warped helmets etc. Yet don't people want a symmetrical, "perfect" set of armor that troopers would truly have. Why not the same for Fett armor.
Just my opinion.
Mike
Well hey, I think It boils down to individual taste, but since I share the same accuracy philosophy as Brak's, I thought I would throw my 2 bars of gold bullion into the discussion.
Basically, the flaws on the costume are essential to the correct look of the costume. I am looking to replicate Boba Fett's costume from the Empire Strikes Back. I want the most accurate costume to what was on screen, because all the parts--flawed or otherwise--all are integral to the look of the costume. I'm just not interested in an "ideal" Mandalorian costume. I'm interested in a "screen" accurate Fett. And that includes all the warps, warbles, and butt-crack thongs that come along with it.
I started out wanting to build a fett display. Once I was sucked into TDH I became so much more aware of what actually made up fetts suit. When I started on this forum I already had my display completed (so I thought). After time its just been cool to go through step by step and upgrade each component to screen accurate pieces. Its like once you're finished, the die-hard Fett builders what to see just how far you can take it. It’s almost not enough just to have a "fett suit" for me anymore, that’s not as much of a challenge as the end all be all screen accurate suit. That’s just a goal for some of us here, and its funny because it’s almost completely unattainable. That’s why we will die trying!
Desloc, you have a very valid point there. As has been mentioned in the previous two posts, there are two factions in prop making. There are those who want to build costumes as if they existed in the real world and those who want to build a prop that matches that of the movie as exactly as possible. As with many, I started out trying to picture Fett in a "real world' environment and planned to build my costume accordingly. I wanted all my pouches, and buttons and whatnot to function as best as technology will allow. However, as I began to do my initial research I noticed that when any prop was made "perfect", with straight lines and symetrical edges, it never LOOKED right. It always looked off. Your mind tricks you into thinking everything is perfect but if you saw a perfectly symetrical Fett helmet you would immediately see that it just doest quite look right. I have become convinced that it is all the little asymetical values and inconsistancies that make the props what they are. It is the same way with people. It is all the irregularities that give us character.
One thing is for sure; there is plenty of room here at TDH for BOTH ways of thinking.
Oh and btw, I paid a crapload more $$$ for my stormtrooper than most to be sure he wasn't symetrical and "perfect". ;)
Desloc wrote:Brak et all,
Just my opinion.
Mike
Hey Braks,
What did you use to remove the gelcoat off the helmet?
I just got mine in today's mail and it looks even more awesome in person!! It was crazy, because minutes after I removed the helmet out of the box, I took it outside in my backyard to show another family member, and I almost dropped it on the hard concrete because the gelcoat is so slippery. Imagine if? *shivvers*
Here's a pic of my WIP ROTJ DP helmet and the new movie-sized fiberglass helmet.
This helmet is simply... A W E S O M E ! !
:cheers
Mike
Mike, you don't remove the gel coat, the gel coat is the hard white coating that is over the fiberglass you are seeing and needs to be there. That is the base for your paint, the slippery stuff is just mold release so that the helmet pulls out of the mold, just wash it off with some good soapy water, sand, prime, paint.
The "gelcoat" is the hard white surface that makes the helmet smooth. I doubt you want to remove that.
You may be talking about "mold release", or something similar. It should clean off with water and a mild dishwashing detergent.
Desloc wrote:The helmet inaccuracies described are there because it was a movie prop, not IMO what Fett armor should be. A true helmet would not have the wavy visor, warped bottom, misshapen rear grille etc. The lines would be sharp, symmetrical and crisp (unless battle damaged). Same with some other details that mimic a prop, rather than "reality".
Just my opinion.
Mike
Mike....
Those faults in the movie helmets make them how they look and make them look bad ass and the ones we love so much.
You make them symmetrical and you fix the faults and what you get is Don Post Fett reg. and DLX, C/A trooper helmets, and GT Trooper helmets!!!!
As Braks mentioned in this thread or another, I can't remember, Don Post "fixed" these helmets, made them symetrical, and crisp and it gave us the garbage we are now working with that just looks just totally off.
The faults make it look good and "right".
This thread is more than 23 years old.
