Boba Fetts Jetpack 3D printed build
Thanks for the info. Rafalfett has a bunch of great stuff listed and at good prices. But, now I can't wait to get printing.
Sent from my iPhone
A delta printer?? What is that?? Amazing work so far , looks great!! Wish my rocket had fins... lol
Sent from my SAMSUNG-SM-N910A
A Delta is a printer that's made to do taller prints, so basically I could cut this jetpack into three tall pieces, or just one if the printer was tall enough. The delta I'm working on building can print entire suits of armor. I got a MK5 suit I'm dying to print
Here's an update for my jetpack. Almost got the main pack done :)
Sent from my iPad
Is there a way you could share the stls? I've been slicing and dicing at these models but no matter how clean I get them the don't quite work...it'd be a great help, but if not , carry on and share progress! :)
-Gav
I'm finishing up the models, and will post them here soon
Sent from my iPad
That jetpack looks more than great! Did you have problems inserting the tank caps or other main parts?
The only one I had trouble with, was the lower tank caps...they were a super tight fit. Everything else was just the quirks of splitting files and fitting them together. I'm lucky with the glue I used...bonded the parts within 10 seconds solid...allows me to work with corners and such while it hardens.
Sent from my iPad
As promised, here's the files that I split. They're cut to fit on a 230X150X140 bed. If you need them smaller, just download the jetpack and load it into Netfabb like I did, and slice away. I believe these should all be cleaned up, but you'll have to orient them how you want. Like I said before, there's a couple of parts that use a lot of support...apologies, but I couldn't do it any other way. I've also included a pic for each file showing where it goes. If you have any problem with the files, let me know.
https://drive.google.com/file/d/0B9KWC9Fh6ZOwNXJQZWozaEJtTlU/view?usp=sharing
How much is this going to weigh?
Mine is about 6 lbs. You could probably drop it down to 4 if you did ABS, two walls, and 5% infill. I used PLA, with four walls, and 20% infill...because PLA is considerably more brittle, but you don't have the warp /shrink factor.
Sent from my iPad
