It was definitely some kind of God's Hand involved which allowed me to create these files.
Most painters don’t share their paint lists for obvious reasons but archive X is pretty straight forwar: Fett helmet color listIs there a list of the paint colors I can purchase for my airbrush or spray cans ?
i dont want this to sound a daft question but, how do you use the stencils im new to the site. is there a thread out with instructions. i just cant find it thanks
Did you figure out how to use the stencils? I can’t find it in the threads either.i dont want this to sound a daft question but, how do you use the stencils im new to the site. is there a thread out with instructions. i just cant find it thanks
No I never. I gave it up as a bad jobRead through the ESB section of this thread for more info ==> Boba Fett Helmet Consolidated Paint Up Threads.
Go to the 3:30 mark.No I never. I gave it up as a bad job
Thank you very much! Tattoo size for me!Ask and you shall receive (download the PDF according to your paper size):
I also added the files to the 1st post.
Hi RafalFett ,
Firstly, thank you for all your work on this. It's wonderfully detailed, and very inspiring!
I have a helmet which I built to your v2 plans. I'm thinking of repainting it using the ultra paint templates.
I've run into a problem getting one of the templates to fit. This also affects the older paint templates.
The problem is with the back left panel. Your v2 helmet build templates give a top length measurement of 146mm, and a total height at the keyslots of 110.5mm, with the keyslot cutout being 101mm tall: and a measurement of 117.5 tall at the ear. Both the actual templates and the accompanying diagrams show these measurements.
I have faithfully built to these measurements... but the paint template for this area doesn't fit.
If I scale it so that the top length of the paint template is 146mm, the template is too tall. If I make it fit the keyslots or the ear area, it doesn't stretch from one side to the other - falling short at about 140mm.
It's just this one template which doesn't fit - the rest all match to within a millimeter or two, which is tolerable for painting.
Which one is more accurate please? I'm guessing it's the (newer) paint templates but it never hurts to check!
-- David.
Thank you very much! Tattoo size for me!![]()
Thank you for the reply, it was good to get a definitive answer.As KaanE said, the ultimate and ultra stencil are made to fit the lineage helmets. For my RWH v2 templates use these stencils for your build ==> Boba Fett ESB Helmet Stencils.
Looks fantasticThe 1st post was updated with the modified back panels (only under the rear keyhole area) as discussed in this thread ==> ESB Helmet Damage.
All the corresponding files were updated.
Holy cow, you just gave me a great idea for a arm band tattoo! Why did I not think of that before? When my wife get's mad I'm going to blame "this dude KaanE on the internet"...Thank you very much! Tattoo size for me!![]()
